The fuse lay out chart is in with the tool kit, or should be.
210 cars have a change in the series where the cigar ligher fuse moved as there was a fuse box change.
If no member puts it up I will find it for you.
Its either fuse 1 in relay box block A, or
is fuse 2 , 15 amp in the box under the bonnet by the hinge, and there should be a chart in there
