I purchased a 1997 sl500 and removed the roof today. When I tried to put it back on, the front pins got semi-locked. I tried to unlock them using the switch but it fully locked the front of the roof in place, leaving the rear pins out of their holes. Now for some reason i cannot get the front of the roof to release so i can get the rear pins into the holes..
As you can imaging the roof is sticking up at the rear and locked at the front so is pretty undrivable!..
I turned off ignition, opened the doors, released the rear heater wire, put it in park, started the engine, tried to release the roof again. I can hear the motor working but the front does not release. Did this ever happen to anyone?! I hope its not an issue with the motor. It worked for me earlier today and released fine..
