Headlight question.
toteimerced
Somerset
E350 Coupe AMG Sport Bluetec.
Good evening, does anyone have an idea, of how to change the LED dip beam bulb, on a facelift C207 coupe, with the standard, non adaptive headlights, I’ve had a good hunt around, but can’t find anything, there’s nothing wrong with my lights, I’d just like to know what is involved, if they do go wrong, these are the type I have, thanks. IMG_3359.png
Usually for C and E class it's removing the wheel arch liner if you can't get your hand in from above.
Normal procedure would be wheel off. I'd put the wheel under the sill instead of axle stands in case the jack failed.
Then usually only 3 centre pull plastic rivets to release the side of the wheel arch liner, which you bend out of the way a little allowing you to get an arm in. Easy access to back of headlight. 10 to 20 mins job.
