Heater Fan Not Working
kelvyn
Luton Beds
W202 C200, Saab9000 lpt
As the heading says. The heater blower on my 99 C200 has started to become temperamental. Three or four times over the last couple of months the fan has refused to work. One day it works fine the next nothing.
Does anyone have any suggestions what the problem might be? Thanks in advance Kelvyn
Motor brushes worn down or possible regulator bad connection.
Check your fuse first, just in case.
I had a bit of corrosion build up on mine which gave intermittent contact resulting in just what you describe.
