well, ive found one problem, the fuse 9 in the boot fuse box was blackend and corroded. i put a new fuse in, lifted the roof manually, and after a lot of messing around, got the roof to open and close on the swich.
the passenger window is faulty, from window fully down, it lifts up uneavenly and sticks before it reaches the lower park position, we had to keep pulling it backwards from the rear top corner. the rivits in the door that hold the mechanism have worked loose and there is about 10mm of play as the window operates, is this a common fault?
the roofs locking mechanisms were all very dry also, so i sprayed them with wd40, and put some copper ease grease on the pins and catches.
the roof was very sticky in its operation, but after about twenty open and shut cycles, it eased off greatly and the roof movement became more smooth and noticably quicker.
however, after about twenty more cycles, it stopped working! it would unclip at the back, and lift the back part of the roof up, then raise the cover , but then not unclip at the front... the button started to flash also.
we had the engine running throughout, but i suspect it has a faulty battery.
is the mechanism hydralic, could it have overheated or lost pressure?
battery is now on charge, roof closed.
