Help Alternator pully
Tezz
loughton essex
A180 w169 2006 2.0 cdi
Had a slight noise from belt and with onset of winter an occasional squeal, at 90,000 assumed poly belt, guides and tensioner wheels, I have all 3 bearings in boot and a new belt, about a week ago it got very metallic sound when I started for about 5 seconds and a sort of snap and I immediately shut of engine, was def a sound associated and combined with squeal on belt.
was first dry day today so I got me jack and axel stands out and thought I would have a look, biggest pain is getting it onto axel stands as I have a 3ton jack and not low profile but dose allow me to get front fairly high lift but have to jack to get jack in lol
so what turned out to be a belt and bearing swap changed as the alternator pulley had sort of exploded and shredded belt all kinds of metal rings around alternator, and the V grooved bit of alternator just feel off leaving it innards on the shaft
so I did hard part, removed compressor left connected, dropped alternator to a point, can access pulley , still yet to work out electrical disconnect to remove from car, but left for now as may not be needed
That was as far as I got as hands gave up could not grip anything and was worried they would seize and be left with car in air and tools all over the place., just put back on ground so they don't steel the wheels (-:
looked at epc for part number but it shows a nut, I don't remember seeing a nut in centre of pulley ? but I was in pain so may not have looked that closely
so I have most of parts just need to order the pully for alternator.
Dose anyone know for sure if need any special tools to change it ? like spline holder or a puller ect or tool to hold shaft ?
any tips , tools I need or you tube clips greatly appreciated.
Many Thanks
Tezz
car is in profile but some times it don't come up.
Its a 2006 A180 W169 2.0 CDI
Thanks,
just need to order parts and tools in one go as I can usually spend max 2-3 hours before hands give up
Tezz
anyone ? I guess I can jack car up again have a look.
EPC shows a nut , yet my WIS shows a spline tool you insert, so guessing I will either need a through socket or an spline tool with a star or hex going through middle, just need to find out which and order
not found anything yet on you tube about replacing this pulley
Tezz
As allways your Reg. or VIN is how to search for parts.
Too many variants for anyone with Webparts access to step through without simply entering the ViN.
I really wish we had some sort of part number request sticky for this for established members? @KillerHERTZ
I have part on order it's the getting old one off that's my issue
I should took pic when jacked up
A bit more info to explain, got part number using vin and ordered
Looking at part that fell off and bits left on seam to be more than just a pulley and bearing
When I looked at pulley on car I thought it need a spline insert with a torx or star in middle.
What confused me was all EPC show a nut
Wis shows a special tool
What I need to know is what tools sizes ect I need to remove pulley
Many thanks
Tezz
I worked it out.
so you need a splined socket to hold pulley and a star drive to hold shaft, the pulley also took out belt and bottom guide wheel looked like it seen better days so I replaced it, managed to remove pulley with out disconnecting air con pump. Tensioner and top pulley felt smooth, no damage that I could see so left them, hope that don't come back to bit me n ****
still waiting on new alternator pulley to be delivered and should be fairly simple just to put all back together
No a fun or quick job but managed it with 3 ton jack and 2 Axel stands., apart from the splined socket and star drive, if doing belt you will also need a tool for the tensioner.
should have investigate squeal sooner, rather than assume it was just belt, but it went very quickly from squeal to pulley failer.
As car was on jack stands and I was waiting for postman, I took opportunity to change engine oil via sump plug and anti-freeze again
This is what happened to my pulley
You probably need this
there will be a torx style fitting in the center of the spindle you turn on against the other
Just done same (Volvo) and its easier on the bench as its pretty tight.
Try this
I've got one of the cheap pulley kits in the garage, £22 on Amazon I think it was.
