Smithy860
That’s good to know.On 639's I have replaced the jacking pads.
The originals are naff, and break tooo easily.
4X Rubber Jacking Jack Pad Lift Adaptor Fits Mercedes C Class T Model S202 | eBay
4X Jack Pad Support Lift Rubber Jacking Point Pads. A124 S202 S124 C208 C124 C215 W124 W202 W208 W210 W220 R129. COLOUR IS BLACK. Original Part Ref. Number : 0019979586. Our Part Number : C406x4. 3 YEAR WARRANTY.www.ebay.co.uk
I don't jack the diff either.
200k miles and 639's being attention hungry it's in the air regularly. Usually 1 axle at a time.
I've 2x 3 tonne trolley jacks. An SGS that I don't favour. It's the 2nd due to the 1st breaking, and this one needs a repair also. It works, it's safe, but the handle comes out as I tow it.
The 1st one remained stuck in the air, so using t'other was fun to get it out.
T'other is a Sealey that I've more confident in.
I use both to lift, left then right, then .... and drop onto stands. Old ones, solid but no longer with any markings.
I chock the other axle as the drive has a gradient.
I’m guessing you jack up near the jacking pads you changed out then drop them onto the axle stands?
When I look underneath it looks solid down the length of the van next to the pinch weld, was thinking it looked decent enough to jack on that then lower onto the pads.
