Help - BAS and ABS errors after changing battery
ceejay
Worthing
E350 CDI
Just changed the battery on S210 E-class and now have BAS and ABS errors showing up telling me to visit the workshop. Presumable some kind of reset is needed, anyone know what?
Chris
Chris
Start the car and turn the steering from lock to lock 3 times, this will clear the ESP lamp
Battery Disconnect - resyncronizing
I think you mean the W210 E -Class, and not s210.
How this proves usefull...
Here is a comprehensive list of all items that need (or may need) to be synchronized after loss of power (i.e., battery disconnect):
Synchronizing Head Restraints:
If the power supply was interrupted (battery
disconnected or empty), the head restraints are no
longer adjusted automatically. To resynchronize the adjustment feature, turn electronic key in steering lock to position 2, move the seat completely forward and the head restraint fully down, and hold respective buttons for approximately two seconds.
Synchronizing power windows:
disconnected or low), the windows cannot be opened or
closed by the Express feature. To resynchronize the express feature, press <close> side of power window switch to resistance point until the window is completely closed and hold for additional 2 seconds. Repeat procedure for each window. The automatic full opening and closing procedure of the windows should now be restored.
Synchronizing sliding/pop-up roof:
disconnected or low), or if the sliding/pop-up roof is blocked during closing/opening procedure, the system has to be synchronized. To do so, turn electronic key in steering lock to position 2, move and hold switch in direction (3), until the sliding/pop-up roof is completely raised at rear, and
hold for additional 1 second.
Synchronizing ESP:
disconnected or empty), the BAS/ESP malfunction
indicator lamp may be illuminated with the engine
running. Turn steering wheel completely to the left and then to the right. The BAS/ESP malfunction indicator lamp should go out.
Synchronizing remote control:
The remote control may have to be resynchronized, if
the vehicle cannot be locked or unlocked. To synchronize insert electronic key in steering lock.
The remote control should once again be operational.
(not my own work, taken from another site)
Thanks Malcolm, worked a treat!
Chris
And Smiddyboy!
Two responses in 15 minutes - this forum is great!:bannana: :bannana: :D :D :bannana:
