25mm long and approx 4.8/5mm diameter?I've got bags full of these . If the thickness is the same .
I spent about an hour with Mercedes Southampton yesterday looking at various part diagrams on the screen and one of them showed this screw. Its a standard part for the OM642830 350 V6 CDI engine as have looked on a number of images and they all have them so bizarre as why its not listed as the amount of people that must drop them every time the filters are changed!It probably does exist, just not sold separately. It may come if you buy the whole housing.
If there is enough meat around the hole just drill it out a bit.Quick update so the the ones from eBay arrived and the diameter isn't correct and the thread is to tight. I phoned Mercedes again and quoted the P/N A0019846629 and was told, of that's a common self tapper used on many models......but not yours, Ok well can you order one so I can test, which they have done. Will see tomorrow if it fits.
I think it is 30mm long, 5mm diameter.This looks exactly like it, I make it 25mm long and 5mm give or take diameter. Does that sound right for that part?
I'll find them in the morning and measure them. These screws are made for plastics .25mm long and approx 4.8/5mm diameter?
Think I'll just give up and glue it.So latest update from Mercedes A0019846629 doesn't fit it is the right length but to smaller a diameter. Original bolt top, new part bottom.
I did, and they cannot find it which is why I asked for help on this forum.Would have been faster in the first place, to take a sample in to Mercedes , and say i want one of these .Truth be known, i bet that screw is used in 100 of places on your car . And it only took 30 post to sort out one screw .
