Help needed
Loverobot
SL63AMG
Hi
Does anybody own an SL63 AMG of the 2009 era that would meet up in the Yorkshire area?
I am having suspension problems and have now been told by three separate people its normal for the car
I really cant believe this but will only know if I am able to go out in the same model ?
I know its an odd request but hopefully someone can assist
Thanks so much
Nick
Thanks for replying - unusually for an ABC car - no!
Its got 25k on the car so pretty young
No faults showing - has had levels and a rodeo all checked out good
No sagging, leaking , squeaking or anything else ABC related really
Basically it shudders / vibrates quite badly over small bumps or 'aggressive' tarmac surfaces. Drives smoothly over smooth surfaces and under load in bends unless the road is uneven
Much worse on drivers side - quite subtle passenger side - and it feels to be coming from the drivers side rear
I believe it to be a bush or bushes on the drivers side rear
Took it to main dealer, a performance car specialist and a merc independent specialist and they have all said its normal and that unlikely to be a bush that's faulty
Al I can say is it doesn't feel normal to me at all having driven all manner of sports cars hence why I keen to try someone elses ....
check tyres
Hopefully your suggestion helps, the OP must of been hard suffering for two entire years
