Stan the Man
I have a set of Steel Wheels 16 x 7J ET37 fitted with 205/55/16 Winter Tyres, ex w203.
Can I fit these to my w204. The spec for w204 Steels is 16 x 7J ET43, fitted with same tyres. I would need to increase the wheelbolt holes to accomodate the larger M14 wheelbolts. I note that the w204 uses the same radiused wheelbolts for both alloy and steel (space saver) wheels.
Is the 6mm difference in offsets acceptable, or do I need another set of wheels.
