Marcel-Anthony
Collected my Daughter from school this afternoon, went to restart the car and the EML light stayed on. Got home and checked it on my ELM 327 (its not the best but its what I have got) and got the following Code P0102 Mass or Volume Air Flow Circuit Low Input.
What I am unsure about is that I have no symptoms for a faulty MAF. It starts ok hot and cold, no rough Idle, No loss of kickdown. I disconnected it and it ran just the same as connected. Car is not running in limp mode.
I am not saying the MAF is not at fault but before I just go out and by a new one I wanted to check with you guys if you think it could be something else. As I have read that some people have done this and it has made no difference.
Can I just add I am no mechanic, using what info I have found on the forums to relay this to you.
I have no other codes coming up.
Advice please, and also are the ECP Mafs ok.
Marcel-Anthony
Marcel-Anthony
