Help
Symptoms sound similar to those which affected my car when the intercooler pump failed, although I've never heard it be a problem on a 230K engine. With the intercooler pump it's temperamental - feels like it's cleared, but comes back.
More likely the MAS/MAF sensor. It's a usual suspect for so many problems!!
Agreed I'd go along with that Rob. The same thing happened to my car 18 months ago, (performance spasmodic drop off), and it turned out to be the intercooler pump that had fiailed. Couple of hundred quid later all sorted :).
If you arehandy with spanners, it's not a hard job, least not on my car.
LOCATION OF PLUG
When looking at engine bay
Right hand side
13mm black bolt cap thingy
Fault
Po243 A/F SW.over Actuat.F.Compr.m16/7
Fault cleared and then drove for 10 mins and fault back
No idea what the fault is!
Thank to all
Merc won't tell me because I didn't have the diagnostics done with them
I'm presuming a/f reffers to Air Flow
:confused:
Car will be in storage for 1 - 2 years at end of the month so i need to get this fixed asap.
:confused:
EXACT LOCATION OF PORT AS PROMISED
Still don't know what fault is though!
