Boxster is white.
I want long lasting. What ceramic coating do you recommend? I may apply that in a year's time ..
Hello, take a look at the new C63 thread I put up yesterday, lots on long term crystal lacquer protections there. Depending on what durability you are after depends on the product. Most waxes will give you 2-3 months of solid beading if the car has had the correct prep work. This will ensure a contaminant free paint surface therefore lasting alot longer.
Higher grade carnaubas made by the likes of swissvax and zymol will give you 6-7 months of solid beading.
The real high end, high grade carnauba's will give you upto a year.
Nano coats such as wolfs hard body will give you 6 months.
Hybrid coatings such as EXO will give you about 12-14 months.
Crystal lacquer coatings such as 22ple will give about 2 years.
C1 will give you about 2 to 3 years.
and if you want the most durable protection then go with a single coat of C1 with 2 coats of EXO. Then your looking at about 5 years protection solid.
Remember the waxes and the sealents bond to a surface that is prepped with a cleaner fluid.
Where nano and crystal lacquer coats bond to a really clean surface that has no silocone from polishes in it. So you must IPA your surface heavily before fitting these coats.
Cheers Mike
