ALFAitalia
- Feb 19, 2022
- Location
- Bognor Regis
- 2010 Mercedes W212 E Class E350 CDI Sport, 2006 Mercedes W169 A Class A170.
Yikes.....not a lot a space to wheelie a bike like that!!!
They certaiy make an impressive noise in railway locomotive formCan't beat a Deltic!![]()
A twin air Fiat 500? I rented one on holiday once. Fantastic fun as the engine is so responsive but you really have to rev them and change gear a lot.I work with a guy that has a twin cylinder fiat car, is a weird sounding thing
You can't beat a petrol V8.
I've been blessed to run two:
- a 1974 Chevy 350 cid small-block V8
- a 2002 MB W210 E430 facelift
Both were legendary motors.
And you can drive into a building, straight into the lift.
When the all singing all dancing Twin Air appeared I checked the numbers of it and the FIRE engine in either the Panda or 500 (I forget which) and the Twin Air only beat the FIRE if driven oh so sedately - more sedately than anyone actually would drive on the road. It was hard to justify the gain against the increased purchase cost - which wasn't only marketing driven but a reflection of the much increased build cost of the Twin Air.The 1.2 4 pot petrol in my OH's Fiat 500 is surprisingly good. It's basically the FIRE engine launched in the Uno 40+ years ago. It's numbers are rubbish but it spins away effortlessly. Italians putting a bit of character into the most humdrum day to day engine. that I've tried) would be the Busso in a GTV6 back in the 80's. As Ian Tyrrell puts it, "An internal combustion engine is basically a wind instrument". I rest my case.
Induction noise is so much more alive than exhaust noise - but sadly lost with fuel injection and associated plenums.However, personally i think any engine's character can be enhanced by fitment of carburettors rather than injection! I do love carbs. A Busso V6 on carburettors is to me just the perfect engine sound.
Thinking about it we have quite a few different engine types in our household - single (technically x3), V twin, inline 4 turbo transverse, inline 4 twin turbo longitudinal, V6. Without exception they are all remarkably different in character which i like. Ive also had a couple of flat 4's, parallel twin, inline 5 turbo and straight 6. Nothing with more cylinders unfortunately.
BMW aimed to emulate that siamesed port sound with its mini and succeeded in that it is similar to a stock A-Series. But nowhere close to one with an LCB. Nothing is.Helped by the exhaust which was a long centre branch 3 into 2 into 1 mated to a Janspeed pipe and OEM Cooper back box. I think what really helped was BL's bodgy engineering where exhaust ports 2 and 3 were siamesed - you had a raucous four pot induction noise playing at the same time a wild three pot-like exhaust note. The combination was utterly epic.
A friend of mine used to run a Mini in Rallycross back in the late 70's / early 80's and also a Mini as a road car. Most years at the end of the Rallycross season he would build a new, higher spec, motor for the competition car and put the end-of-season competition motor in his road Mini.When I built a stage 2 Mini I stuck a Dellorto 40 on it. I ran that open, quite literally; there was no filter and, to make the carb fit, I took a small panel out of the bulkhead.
I remember running my Sprint sans airbox - the sound was intoxicating! I remember opening the bonnet once though to be met with a cloud of white fuel vapour! Oh how we laughed (and stood far back)!Occasionally, I'd take the airbox off my 33 just so I could hear the sound track of the twin 40's more clearly. Childish but fun.
When I built a stage 2 Mini I stuck a Dellorto 40 on it. I ran that open, quite literally; there was no filter and, to make the carb fit, I took a small panel out of the bulkhead. It was running a hot cam and a high compression head with big valves and the sound track was epic.
Yes, carbs. Nom nom.
