stephenmercedes
Indeed LOL I could also cut a hole in the floor and stop using that stupid engine thing and use my feet a la FlintstonesMaybe stop pressing buttons...
... i think it's just the way they are but it's a 100% better than my old mk4 golf.
You just made me remember the best car I ever owned for windscreen demisting - my 1990 Ford Escort RS Turbo! It had a 'quickclear' screen which had in built heating elements, I swear the screen cleared in 30 seconds of the roughest crud the weather could throw at the car, never even had to de ice the screen in all the years of ownership, just brilliant...
Because Ford still own the rights/patent for this?Never understood why more manufacturers do not add this
Our SEAT Alhambra had the heated screen, brilliant. Something to do with the Alhambra being a Galaxy clone?
Mercs can be optioned with the heated screen but only as part of a Protection package (diplomats/oligarchs etc.. bullet/bomb protection )
Had this on a 1987 Scorprio (Granada Mk3)... worked quite well.Ford used to licence the use of heated front screens to other manufacturers, it was (possibly still is) an option on Caterham cars
Just poured a watering can of water down each drain hole and it went straight through to the wheel well, so both channels are cleared, worth doing though just in case!My 203 takes a little while as well (probably about 5 mins) and as mentioned the passenger side seem to get more air then the drivers, it'd be nice if with the UK pack they changed that.
It's worth cheking the drains in front of the windscreen i always point the preesure washer down mine but i recently done some work under they wheel arch trims and found they were still blocked.
There's the little bugger, although i wasn't getting a damp footwell it's a common problem and worth doing. They drain starts right at the bottom of the windscreen two holes one each side. After that keep the windcreen clean on the inside and i do wipe it with a micro cloth when it's bitterly cold but that's about it really i think it's just the way they are but it's a 100% better than my old mk4 golf.
