Tony Russell
- Jul 21, 2009
- Location
- Glasgow ish.
- Vaneo. 1.7CDi. I know. Stop laughing ! I need an MPV and it had to be Mercedes. OK ?
You know this old chesnut ?
So the car has been in the garage for 3 whole weeks now.
I hired the seating tool for them and printed off loads of material from here.
I dropped in last night to see what was happening.
I walked in and discovered the injector clamp held in with a home do re-threaded piece if stud and held in place with two nuts.
That was bad enough (seeing the material wasn't engineered for the specific stresses of the purpose), but hey were also running the enhgine under the boss's instruction to see if a bit of carbon would block the sllight leak that was evident at the seat of one injector.
FFS !!!!!!
I have read enough now to realise that the action alone of running with a leak will only cause further erosion of the seat.
That and the fact that the home-do stud thing is just waiting to either shear or pop off.
So they showed me the original bolt, and it was clear that the head was threaded as there were bits of it in the bolt.
That should have been obvious first time it was removed (if it was there already), or it was caused by being overtorqued when it was replaced (they hadn't used new bolts).
So now I have a perfectly good car which is unuseabble because there's nothing to hold two injectors in.
At this point, I have asked them to do no more work on it, other than build it back up.
They seemed to be unaware of the danger of trying to tap it up a size and going into a water or oil channel.
Aaaaaaaarrrrgh.
So, what are the options ?
I've booked it into Merparts for Wednesday.
I'm thinking the obvious repair is a helicoil.
I've heard they are better than the real thing.
I've also heard they are worse than the real thing.
The other option is to get the head our and replaced / rebored / whatever.
But that means not using a std fixing bolt, and that's not preferable.
And that's before I consider the problem of discussing what to pay said garage.
I paid them for the original job, this time there was a new injector, bolts and washers.
I would obviously pay for them, but I'm thinking that I should not be asked to pay for the skill aspect, as it's kind of, er, you know.
But they have my car and they have my key, so I don't have the advantage if they disagree.
Someone suggested getting all my money back and having them pay for the expert bloke.
It's highly unlikely, and I'm not the confrontational type.
Plus, I stupidly didn't get a receipt, in exchange for a slight discount.
Had I just put it on my card, they might well have recovered it for me.
Obviously I see things from my perspective, and I have to appreciate the garage's view too.
Anyone care to rationalise me - or slap me round the head ?
I'm not trying to be insulting... but...
YOU clearly don't know what you're doing.
YOUR GARAGE clearly don't know what they are doing.
I am at a loss to explain why you think that with the combination of the above, all you have to do is keep taking bites of the apple and eventually you will end up with a whole, fresh apple...
Take the car to someone competent, then send the bill to the current place. Small claims if necessary.
FFS !!!!!!
Aaaaaaaarrrrgh.
