Hi all i am very new to my mercedes clk 320 and i recently found that one of my spark plug leads is sparking on the outside of the lead and it seems to b shorting out HELP advice needed many thanks
If you can access the lead in question you could try a blob of neutral cure [ not the common or garden acetic acid stuff!] silicon sealant as a temporary fix. Silicone Adhesive Sealant : Epoxies & Silicon Sealant : Maplin Electronics If the problem is localised mechanical damage to one lead fine. If however its an indication your leads are past their sell by date a new set of leads is the answer.
