Indicator (trafficator) fault ?
c240yaz
I nipped out of work at lunchtime today, indicator sound missed a beat, while waiting to make a left turn, twice.
On my return, made several turns, problem did not re-occur.
Could this have been a "1 off ", or is something on the way out, needs to be looked at ?
(Note, auto electrics are not my strong point).
When a lamp has gone it flashes faster, so not that, see how it goes
TV, Definatly not a bulb or faster flashing.
This was a case of missed flashes. 2 missed clicks, starts clicking again, then misses 2 clicks, clicks again.........
On older cars I worked on, this was generally the flasher unit (tin box type capsule) that needed replaced. On modern MB, I have no idea if the same type unit is still used ?
Flasher = front right sAM.
BlackC55 and TV, Thanks for this. Is it item 10 in the drawing ?
Also, where is the RH Sam located, and is the "item" replaceable without Star dagnostics or other pittfall ?
I do not think that it needs coding,you have 2 boxes under the bonnet, the other box contains the engine modules, lift the lid to see if it is dry inside
yes item 10
Is it O/S or N/S ? I hope I don't need to buy a new one. Good idea to clean all contacts within, with electrical alchohol cleaner ?
Part A2035451601
Type: STEUERGERAET
Price: £203.03
£182.73
Part A2035451601
Type: STEUERGERAET
Price: £203.03
£182.73
I tried to evade the question the other one that it is not, looks like this one . I would leave it for a bit, check that no water is in the box and see how it goes
http://www.detali.ru/cat/oem_mb2.asp?TP=1&F=203061&M=112%2E912&GA=722%2E696&GM=716%2E623716%2E634&CT=F&cat=65F&SID=54&SGR=080&SGN=07
TV, looks like a weekend job for investigation purposes alone, preferably a dry day with daylight.
It's almost pitch black outside here now and it's only 15:45 Hrs.
Normally would still have sun up, but heavy black cloud coming in from NW Atlantic.
