Uncle Fester
Hi all, I'm looking for a little advice here, as a second seal has started to leak/let by.
I had the front one done by a local diesel specialist at a cost of £320 and although it fixed the problem (for now) I was kind of expecting them to clean the carbon residue off the entire area, but they only cleaned the injector they worked on.....
Anyway, less than 2 months later (about 2000 miles) another seal is letting by, and frankly I'm loathed to take it back there as their costs seem a bit high, and I certainlay can't afford £300 per seal to get the other three done.
So my question is, what do I need to get (tool wise) to do the job myself?
I know I will need and injector removal tool, and either a seat cleaner or re-seating tool, I would like some advice on what are the best tools for the job.
Also do I need to buy the MB white grease for refitting the injectors, or will copper grease work?
I know that I'll need to replace all bolts, clips and copper seals, I just don't want to buy tools that are not up to job.
Have seen these:
http://www.partsformercedes-benz.com/product_info.php?products_id=2793
http://www.partsformercedes-benz.com/product_info.php?products_id=3155
Thanks in advance for your wisdom.
Have seen these:
