MBV6
Just thought I'd share..was having bother after a flat battery, even after charging the battery overnight the instrument cluster wouldn't come on and was planning on changing it..so driving to work with the wireless OBD2 plugged in so I had the dash for speed etc and it showed the battery voltage...the very second it hit 13.3V from 13.2V the cluster sprung to life! I had changed fuses, unplugged battery, took it out for an entire night, read through the forums for cluster faults etc thinking surely it should work while attached the charger but nope it didn't just until it got enough charge to peak over 13.2V...moral of the story a dying battery can look like SAM problems or a cluster problem on these older wagons... new battery on the way!
