Intake port shutoff actuator motor faulty
Pasio1118
Manchester uk
Mercedes Benz e350 sport coupe V6 om642
Friday after work I noticed that my mercedes Benz e350 with engine om642 won't go over 3000rpm with management light present on the dashboard.Today I had car scanned and my guess is that actual actuator motor is fried. Can you guys confirm maybe with your own experience that this is the case. Thank you all for your help and I wish everyone a happy and peaceful Christmas
It is very common fault in OM642, turbo drips oil on motor and eventually it fails. However, check fuses first.
I disconnected all to see if Turbo leaks and I can see it's leaking on motor/connection plug. I bought new seals and resistor plug and will attempt repair/bypass of the actuator tomorrow. Hopefully it will fix my problem. I would replace the actuator itself but this is too expensive for me at the minute. Thanks for the info 😌
Problem sorted. Turbo sealed and resistor adapter installed. Check engine cleared by obd Bluetooth reader that I bought from Amazon for £17.Well happy that my coupe is back in the road and I didn't spend money that I don't have for costly repairs 😃Is this method of dealing with failed motor will be a permanent fix?
Good job buddy , it’s pretty permanent. My resistor has been in for 40k miles . If I remove the batwing for any reason I normally just change the resistor for a new one just in case .
Thanks! That a good news 😀
Mate my resistor the fancy one just fried and car back in limp mode again. What tape do you use to isolate resistor please
What tape did you use to isolate resistor
But to close the sleeve you have to use lighter? Sorry for dumb questions I just want to do it properly
Wants to bodge it properly. Priceless!
