AndrewHill
Makes sense, I thought you meant closer to the door seals, near the actual seals themselves [emoji23]The cable goes under the trim, or under the carpet - it's hidden and it won't come loose.
Last question I think, if I'm wiring it up into my new 2din unit, would I need to remove the centre console to get it in? Or is there an easier way? I don't fancy taking it apart to that extent you see [emoji23] considering drilling a hole through right at the back near the glove box and hooking it through with a coat hanger [emoji41]
Sent from my G8141 using Tapatalk
