Intermittent kompressor, advice please.
s1gar said:
my engine is slightly different from your pic. can someone comfirm this but the pipe with the recirc flap coming out of the airbox goes to the kompressor? my pipe is not visible and comes out from under the airbox. i have the other pipe coming out from where the recirc flap pipe is situated. i dont know whats up with mine but i do know its expensive and peeing me off to some tune. i am gonna check to see if i can locate my recirc air flap and see if its stuck....can anyone answer if when the check engine light comes on it reduces the performance of a engine????
s1gar, I've labeled some parts on the picture to make things a bit clearer for you but you will have to wait for advice from others as it sounds like our cars are far from similar and unfortunately I am not familiar with yours.
I have a ticking or clicking noise also, it appears to be coming from a high sped relayor ??? mounted on the nearside wing with pipes attached. The noise stops when the engine is warm not sure what it is or does?
nigel cross said:
big dusty
That like goes nowhere or is it just firefox? :bannana:
Sorry, but that one has gone straight over my head :D
BigDusty, the part you have circled is the power steering pump and is not connected to the compressor.
Sorry, for going over your head. What i meant was, the link you posted doesn't go anywhere. Or is it a strange no go if you use firefox for surfing :bannana: :bannana:
No worries, my hair piece in still intact.
Think I've worked out this posting picture lark now. Strange thing is it worked the first time but not the second. Computers, worse than cars when they go wrong!!
I know, I was pointing out the area where the ticking noise was coming from when my kompressor stopped working, just so happened to sound like it was coming from the pump but it must be something very close by. As soon as the kompressor started to work again the noise disappeared. :confused: Just wondering if anyone could shed some light on this noise and why from that area.
Anyway, have fitted a new Air Recirculation Flap and will have to see if this solves my problem, fingers crossed :o
Update.
I can feel a bottle of champers coming on, but I won't push it just yet.
Found out where that ticking was coming from, this time I was better prepared and had a long screwdriver with me so I could pin point where the sound was coming from and I did.
Problem is I don't know what this part is or what it does, but I will try to describe it. (Part No. 001 140 99 60)
It's black, made of plastic, has the words MOT and Motor embossed on it with an arrow pointing out the direction of air flow, about 3" in height, has two rubber pipes connected to it which supplies air, is also wired up with a two pin plug, has a rubber ring around it to secure it to a metal hook and it's just under the Brake ABS Unit.
On closer examination I tried to unplug the cable, it was so difficult I had to carefully prise it off with a screwdriver. The two connections were very badly corroded and were obviously causing a very poor connection for the electric current. I also pulled the rubber pipes off then decided to start the engine just to see what would happen. The engine was misfiring and the tick over was all over the place.
Cleaned the connections and WD40d them, put it all back together and took the car for a test drive. Lets put it this way, I thought the car was quite powerful when I first bought it but when I put my foot down "HOLY C**P", my teeth almost ended up in the back of my throat.
I'm going to MB tomorrow to see if I can get this part replaced in case it has been damaged in anyway.
Even though I have replaced the Air Recirculation Flap (which I soon found out did not cure the kompressor problem) and even though the part is on loan have decided to keep it just to be on the safe side.
Any ideas what this part is and what it does, I will be very interested to find out.
BigD
let me know what the mystery part is could you???
Is the problem it's too tucked away for a photo or you don't have a camera? If the later I will try and follow your description and find the part tomorrow for a pic.
I'll be taking the car to MB today and will ask them what it is and what it does. Will get you the details ASAP.
BigD
You can take a photo if you get close enough but I'm gutted that I've lost my camera otherwise I would of taken a picture when I had this troublesome part removed from the car.
Note, I saw one of these things in a Haynes Manual, picture was not that great but by the look of it, it may not of been black in colour, mine is but not sure about yours. Hope you get a good close up.
BigD.
The Haynes manual does not cover the c230k.
I know, just the C230, but there was a picture in the engine section and I could make out this part in the background. Thing is, I'm not saying this part has anything to do with the Kompressor because when I disconnected it the kompressor still worked. Because this part was failing was obviously affecting everything and causing misfiring, irregular idling and it must of triggered something in the ECU to disable the Kompressor. Still trying to work this out.
I've been in touch with MB and I'm waiting for a reply for an explanation.
BigD
from the description you might have disconnected the mass airflow sensor.
GrahamC230K said:
Looks like a windscreen washer pump!
It does doesn't it but when I removed it and started the engine it ran like a dog, but the kompressor still worked. With such a poor connection it must of been causing all manor of problems and eventually and somehow triggered the kompressor not to work. :confused:
Been testing the car out today and not only has it behaved it self but is much more responsive and is driving like a dream. Has definitely made a huge improvement. :D
I didn't realise the first time, but I think you have hit the nail...
Let me try and find a pic. The location and description is perfect and would expalin the engine running rough when disconnected.
LOL surprise surprise another symptom of the ever faulty MAS.
