It is in your opinion "bad driving". That's just a little arrogant. By all means discuss the various methods we all use, but don't accuse others of bad driving because you do it a different way.
I have always used engine braking and brakes...why not? Engine braking does not have to be violent, but by matching engine speed and then easing off you will get the effect you want without undue wear to the trans.. I presume you use kick down? Now, that is a violent and stressful action on the gearbox, and a very satisfying thing. On the other hand you can use the tip. (sic) function to drop a gear or two for the same reason, just as in engine braking...what's the difference?
You use a combination of brakes and engine braking. OP question related to engine braking only.
Forces cause wear. Why subject the transmission and engine to them when a dedicated easily renewable system is provided?
Kickdown - braking is the topic of this thread.
Would you pass any driving test focusing your braking on the engine? Could you convince a judge that you had done everything you could have to ensure safety while confessing to applying braking to the rear wheels only?
It is not arrogant to have a view on what constitutes good or bad driving. You too have a view. It is the threshold at which you will not permit a person to drive a car you own.
