I'm looking to buy an old W210. I've found one locally which I'm tempted to buy, but I'm a little concerned about a couple of details.
The seller has lost the service history, and only has a couple of recent receipts, MOTs and half of the V5 doc (new keeper part).
I'm a worried about the VIN plate. I took a picture (attached), and wanted to ask you guys about it.
Can you tell the full VIN from this plate?
Should it not be welded rather than have screws?
The VIN on the MOT checks out with the Car Check I did, but I can't tally the VIN against the plate. The first 7 numbers match, and I have looked at the paint code and option code decodes which all look OK.
Also, I thought W210's had the VIN on display through the windscreen. I couldn't see it there. Are there some cars that don't have it here, or has it been tampered with? It certainly didn't look like it had been touched.
Obviously I won't buy the car without matching the VIN on the MOT against one stamped on the car somewhere. Where else can I look for it?
