Kompressor intermittent
russcrf
Hi anyone, my E55 AMG Estate 1994 has never let me down but in the last few weeks when the engine is warm to hot the kompressor does not always kick in, when its off I trundle along for a mile or so, and bingo it cuts in quick as usual. My indie has changed drive belts (they were worn anyway) but no change, usual chirrup from the kompressor and off like a scalded cat.
My daily journey is from Ramsgate Kent to Edgware North London 105 miles each way, most days/evenings 1 1/2 to 2 hours driving, so when its not working its a real pain.
The car is going in 10/03/10 for discs and pads all round and the usual service. Iv'e been reading about intercooler or magnetic clutch which do you think it might be?
Of course when he plugs it in tomorrow it might show the problem but who knows,
Many Thanks
Russ
Intercooler pump is the most likely cause.
It does not often bring up a fault code!
hi
i agree with BlackC55 common problems as i have changed a few.
acid
As if it were needed, I can thrice confirm the IC pump is the likely cause.
Thanks to you all it was the IC pump £204.00 + £55.000 to fit. All back to normal now, brilliant to drive.
Thanks again.
Russ
