John Kerr
W203 220 CDI will only rev to about 3k.Have renewed the obvious things.MAS,BPCV,BPS,as far as I can tell the vacuum system is ok,the EGR valve ok.Has anyone had a cat blocked,if so what are the symptoms.Has anyone had inlet manifold problems ie the flaps breaking and if so what happens.I know the linkage works as the last diagnostics we could make it work with Star.The only faults were a stored fault "Boost pressure low".
Some one out there must have had a similer problem.I would be very happy to hear about it.
Many thanks in advance. John
