Leaking soft top
Erica
Ely Cambridgeshire
Mercedes CLK320 Avantgarde
Hi has anyone got any suggestions I have the CLK320 soft top and it has started leaking, drivers side roof where it meets the windscreen . Has anyone else had the same problem? Any suggestions who would be able to fix it ? Would it be a trimmer ?
Erica
Welcome to the Forum.
It would help us to assist you if you give a few more details such as model type (i.e W208, W209 etc) or if you do not know this then the year of registration.
Also, if you let us know your general location then members may be able to suggest a good local Independent Mercedes specialist who can help you. It may just need an adjustment or a seal replacing.
:thumb:
I do not know that area but I do believe there are a couple of well respected Indies (Independents) not too far from you. I am sure others will post and give you details.
How long have you had the vehicle?
If it's coming through the seal I'd treat the seal with Gummi Pfledge. You may need a couple of applications.
I'd recommend anything with a decent amount of Krytox used as a lubricant in the area of the leak to help the seals fit each other.
