Hi. A week ago, my local garage replaced the dual mass flywheel with a solid flywheel whilst fitting a new clutch and slave cylinder in my 2003 W638 Vito van. It was in a bad way and they recommended going to a solid one.
THE PROBLEM: I collected the van, drove about 500m and it went into limp mode! I took it back to the garage. A couple of days later they said it was ready to collect again. The mechanic told me I needed a new EGR valve so as a temporary fix he put a 'plate' in the middle section of the EGR valve and said that would work until the EGR valve was replaced! This all seemed odd to me as the engine was running great before the clutch went. He said it wasn't anything they did whilst fitting the clutch etc. I was reluctant to leave it with them again, so I drove it home for further checks but I still have the problem!
TO HELP YOU PROVIDE AN ANSWER (please), I can tell you that I have checked that all tubes, hoses and wires around the EGR valve are connected correctly. I have removed, cleaned and vacuum tested the EGR valve. I have removed the 'plate'. I have tried plugging the vacuum pipe where it goes onto the EGR valve. I have replaced the clutch switch. Usually, she revs above 3000rpm when I first start her up but when I get into 3rd or 4th gear the limp mode kicks in and she won't go above 3000rpm. If I switch off and restart, sometimes it clears the fault but not for long.
I would welcome any advise on pin-pointing/fixing this fault ASAP, please.
