Peter DLM
- Aug 24, 2007
- Location
- Milton Keynes
- 19 reg CLS 350d, 67 reg AMG GT R Caterham Levante
Driving to a location an hour from home, about 30 mins into the journey the dash claims that the BAS has failed, and then a minute later that ESP has also failed. Then 5 mins after that another warning saying 'Battery/Alternator failure' and 'Visit Workshop'.
Now as the first two problems happened 9 months ago and disppeared by itself I ignored it. I also ignored the battery/alternator one as well, thinking that after I restart the car it'll all be ok.
Left the car parked for 6 hours and when I flicked the ignition on, the Comand system advised starting the car within 3 mins as the battery voltage is too low. I've had that warning for a year, as I only use the car once a week/fortnight for short journeys and after a 30 min drive it was all ok.
Now, I was quite shocked to see it after a sold hours driving. It seems fine and I drove off with the sat nav on and the climate on full. The Battery/alternator warning still on. 2 mins later the Comand turns off... I start thinking 'here we go'
Then the car looses a lot of power, foot flat to the floorboards and baring reaching 10mph. I pull over and it all dies.
Just a 'dead battery' click when you turn the key.
Wait 10 mins and it starts again, but won't change out of 1st and 20mph is the top speed.
My mate is behind me fortunately, we install his battery into my car. I suffer the indignaty of a V reg Renault Laguna diesel Estate saving my merc.....
We drive 40 mins to his house, the battery/alternator warning still on. I'm sure I am running a total loss ignition system and leave everything off. The BAS and ESP warnings are gone, and instead a sold dim battery/alternator warning.
We leave a battery charger on the merc for an hour and deem it safe for me to make the 30 min run home. Mistake !! I make it two minutes before I get the loss of power and 10 mph max speed and just about make it back to his house. The battery is completely dead, the thinking is now that there is some sort of earthing issue and the car was draining the battery all the time it was parked, despite the charger on it.
Another fresh battery into it and I drive home. This time NO batter/alternator warning, but the BAS and EDP warnings are back.
So, what the hell is going on?
Alternator seems ok, but it's charge not making it to the battery. Is there a regulator of sorts to manage the battery charging? Could it be screwed and dumping all the alternators charge to earth? What drained the battery so fast when parked? There were no visible signs, did it all drain to earth as well?
