Oh no The poor old girl is having some troubles!
96 S280 with the M104 engine - 130k miles, last serviced with new plugs and oil about 12k miles ago looking at the invoices.
Since buying her 10k miles ago she has had a very occasional stutter on warm idle - a single miss/burp and then back to normal, it didnt bother me at all.
In the last two days she has twice ran dog rough on me - once when ariving at work so I couldnt investigate and then again just now when arriving home - its probably not a coincidence that this happening after a long motorway run at constant revs??
She will run rough right up through the rev range, feels like its missing on 1 or more cylinders. She will still rev and drive though and its much more noticeable when stationary/idling. Oil pressure and temps remain perfect throughout.
Interestingly if you turn her off and restart her immediately the problem is gone and she drives off nice and smooth like there was never a problem.
The only other problem she has at the moment (and I mention it in case there is a link) - she has an oil leak that I believe is either coming from the front crank seal or possibly around the head - typical M104 fare! Losing about 1L every 1000 miles - she is wet around the front and on the bottom of the engine.
Any thoughts appreicated!!
