Dec 22, 2013 #1 B BlueQuinn Active Member Joined Jun 4, 2013 Messages 150 Location London Car Mercedes-Benz 300TE-24 This connector has broken plastic and therefore can be wired either way round. Is this the correct way? Thought I'd make sure before I seal that oil leak.
Dec 22, 2013 #2 M mejermy Active Member Joined May 18, 2009 Messages 364 Location IoM and Languedoc Car S211, V126, S124 x 2, W169 This any good? It's the closest I could find to the W124 M104 HFM when I rewired mine, but IIRC was identical. The bit you're asking about is at the top of the sheet. Attachments C280HFM.pdf C280HFM.pdf 36.3 KB · Views: 21
Dec 22, 2013 #3 jaymanek Authorised Forum Sponsor SUPPORTER Joined Nov 29, 2002 Messages 16,848 Location Nuneaton Warwickshire Car Lots of Mercedes! Im not sure it should matter... it will either be closed or open AKAIK..
Dec 22, 2013 #4 grober MB Master Joined Jun 22, 2003 Messages 31,711 Location Perth, Scotland Car W204 ESTATE pin 2 red/black wire = 12volts [ ignition on] pin1 brown /blue wire = to engine ECU
