Old spanners
- Apr 15, 2017
- W203 C180K
Having read a lot of useful info for a while I am now in need of some guidance.
On my 2004 C180 I have a P0170 code which has reoccurred after a year. It was cleared by replacing the after cat O2 sensor.
On investigation the pipe from the cam cover to the intake after the Maf showed some oil weeping on the outside. I cleaned the intake from the air filter housing with an aerosol (hopeful in the extreme) but had to remove the filter housing, throttle body and sensors when I found a fair amount of oil in the inlet tubing.
I have cleaned all these but looking at the cam cover where the pipe connects to what I take to be an oil separator is where the problem is.
Could the gasket have failed here or the plastic cracked to allow the inlet to suck in this oil?
There is no loss of performance or other problems except perhaps a small drop off in MPG. I have blocked off the hose at the cam cover for the moment.
Any info would be very much appreciated.
