Dieselman
Banned
- Jul 13, 2003
- Peugeot 403 Convertible
Originally posted by Steve_Perry
If you think about how the MAS works in the petrol cars (I dunno if the diesels are the same) it's basically a heated wire wafting in the breeze of the air intake just after the air filter, the more air travelling into the engine the cooler the wire gets, resistance changes with temperature so a signal can be fed back to the ECU. S.
It's not quite like this.
The 12V heats the "hot film" to a set temperature which is measured by a thermistor. The amount of current required to keep the film at this temperature is measured via a comparator circuit. The greater the flow of air or the cooler the air the greater the current required to keep the film at the set temperature.
Thus the feedback voltage, (0-5v), increases with airflow, although not necessarily liniarly. Bear in mind also that different engines ingest different amounts of air, so MAFs have to have different characteristics.
Say my engine injests 3000cc of air for every two revolutions whereas a 2 litre injests 2000cc. (Not really true as ther is only about 80% cylinder filling without turbo / super charging the intake air.)
So if the same MAF were used and the output was 4.8v at 5,000 rpm for my car it would only be about 3.16v for a 2000cc engine.
As the same ECUs are used this wouldn't be too good.
