IFFY100
Poor people don't carry wallets, so it can't be that. LOLAre you sure the ground is level ?
Reverse the cars parked direction and re measure ?
Your wallet is in the car on the drivers side ?![]()
I will remeasure
Hope those are the correct springsAre the springs sat correctly in the (top) rubber shims and/or the lower arm where the end of the spring must meet the 'scalloped' out part of control arm the 'shim' and control arm ? It would be a hell of a coincidence for them not to be seated correctly front AND rear.
But its possible (I suppose) I have just done this job myself (shocks and springs) so I can see how someone might get it wrong.
This bit ....
Snug into this bit .
OK , Im showing the bottom of the springin the top photo with the stainless steel shim in place which sits between the spring and control arm (no rubber there) , but we get the idea. This...
Incidentally on my car there a 4 different part numbers for the rubber shown here giving different ride heights. I used WD40 on installation into the cupped part of the car body allowing the new (tight) rubber to 'squirm' into place a bit once the car was lowered .
Were all of the elastomer pivot bushings tightened/torqued when the car was sat under it's own weight (or the hub lifted by a separate jack before tightening ?
Bit of a mystery OP , let us know what you find.
PS: I measure ride height before starting the job from the wheel rim , not the ground, kind of means tyre pressure or slightly uneven ground is not an issue. On replacing springs , rear shocks , all new 'rubbers' ride height was exactly the same after a short test drive than it was on ancient springs of dubious heritage.
PPS . Shouldn't tell you lot this really ,but I knew one of the rear springs was broken when I took it for an MOT , it sailed through. It was just the bottom inch or two but it did not affect the ride height at all and could not be seen without getting right in there. Naughty really !
Will let you know. Thanks.Are the springs sat correctly in the (top) rubber shims and/or the lower arm where the end of the spring must meet the 'scalloped' out part of control arm the 'shim' and control arm ? It would be a hell of a coincidence for them not to be seated correctly front AND rear.
This bit ....
Note . This is all S203 2006 C class.
On its weightDid you have the car still jacked up or sat on it's wheels before tightening everthing back up.
On its weight
I don't know anything about your model. If the shocks are vertical it shouldn't be a problem but if there at any kind of angle they need to be tightened whilst the weight is on the suspension so as you say the bushes are not under any stress. This can be achieved by lowering the car down on to blocks under the wheels to give you enough room to get to the bolts.I can understand why on its own weight when changing the suspension arms because the rubber bushes twist . But springs and shocks ???? , especially on the w219 chassis
