Mercedes Benz Oil Specs listed in full
oilman
Banned
South west
RX8
MB 226.9
Multigrade engine oils for gas engines (CNG) based on Series 300/400 engines.
MB 227.0
Monograde engine oils for non-turbocharged diesel engines (Series 600).
MB 227.1
Multigrade engine oils for non-turbocharged diesel engines (Series 600).
MB 228.0
Monograde engine oils for turbocharged diesel engines. Oil change intervals up to 30,000 km.
MB 228.1
Multigrade engine oils for turbocharged diesel engines. Oil change intervals up to 30,000 km.
MB 228.2
Monograde SHPD engine oils for highly turbocharged diesel engines.
MB 228.3
SHPD engine oils for highly turbocharged diesel engines. Extended oil change intervals up to 45,000 km.
MB 228.5
UHPD engine oils for highly turbocharged diesel engines. Extended oil change intervals in light-duty engines up to 45,000 km. Up to 160,000 km possible in heavy-duty diesel engines (with service interval displays).
MB 228.51
UHPD engine oils for trucks fitted with exhaust gas after treatment. Low ash content required.
MB 229.1
Engine oil for car gasoline and diesel engines. More stringent than ACEA A2/A3and B2/B3.
MB 229.3
Engine oils for cars with extended oil change intervals (30,000 km).
MB 229.31
Engine oils for cars with exhaust gas after treatment. Low ash content required.
MB 229.5
Fuel Economy engine oil for even longer oil change intervals (vehicles from 2002 on) with service indicators. Special, stricter requirements than ACEA A3/B3. For use in all car gasoline and diesel engines. This oil also complies with 229.1 and 229.3.
MB 229.51
Very high performance oil for engines with diesel particle filters and extended oil change intervals. Better fuel economy than MB 229.5.
You'll find the most popular ones for cars also listed here http://www.opieoils.co.uk/c-716-mercedes-benz-engine-oil.aspx
Cheers
Guy
Opie Oils
Here are the gear oil ones
MB 235.0
Hypoid gear oils SAE 85W-90, 90
MB 235.1
Gear oils SAE 80, 80W/85W
MB 235.4
Synthetic gear oils SAE 75W/85W
MB 235.5
MB 235.6
MB 235.7
Fuel Economy hypoid gear oils
SAE 75W-85, 85W-90
MB 235.8
Hypoid gear oils SAE 75W-90
MB 235.9
Axle oils
MB 235.10
Manual gearbox oils
MB 235.11
Fuel Economy manual gearbox oils for extended change intervals
MB 235.12
Manual gearbox oils SAE 30, 40
MB 235.13
Fully-synthetic manual gearbox oils
MB 235.15
Hypoid gear oils SAE 75W-85 for rear axles with differential look
MB 235.20
Mineral axle oils, LD, SAE 80W-90
MB 235.27
Retarder oils SAE 10W, 20W, 30, 40, 50
MB 235.61
Hypoid gear oils, AMG
MB 236.1
Gear fluid (DEXRON III)
MB 236.2
Gear fluid (TASA)
MB 236.3
Steering gear fluid
MB 236.5
MB 236.6
Gear fluid (DEXRON II D)
MB 236.7
MB 236.8
Gear fluid (DEXRON II E)
MB 236.9
MB 236.10
Gear fluid NAG1 (ATF)
MB 236.11
Gear fluid (ATF)
MB 236.12
Automatic Transmission Fluid NAG2 (ATF)
MB 236.13
ATF for power distributors
MB 236.20
CVT oil for Autotronic transmissions
MB 236.81
Gear fluid (ATF)
http://www.opieoils.co.uk/c-717-mercedes-benz-gear-oil.aspx
Cheers
Guy
