Lfmullin28
- Dec 27, 2013
- 1998 Mercedes E300 Elegance 3.0 TD
Hello all,
I have just taken ownership of my first Mercedes. It's a 1998 turbo diesel E300 estate. I have never been one for being very technical minded about cars, but I do search, read and try to teach myself.
I have a somewhat odd issue with my new purchase, it's a real pain to get started but once started and warmed up it runs pretty much ok. One morning I went to start it, and all it did was turn and turn and turn and just as it felt it was about to fire up it gave up. I flattened the battery doing this so from a jump start it eventually started, then ran fine all day long until the next morning when the same thing happened.
This time I had charged another battery, popped it in an it fired right away but did run rough for a while, but again ran fine all day.
So that evening I disconnected the battery, went out the morning after reconnected it an it started right away but again was rough for a while.
So I've come to the conclusion I have something draining the battery and low and behold it was the radio as some novice has clearly messed the wires up at the back as they been cut and had an ISO connector put on.
So hurray I thought problem solved! Just get the wires checked.....but no
The very next day I noticed the coil light would come back on after starting the car, and a cloud of smoke which smells oily. I took the glow plug relay connector off and tested each pin 1-6 I put the positive into the connector pin and the negative to earth on each one with An ohm meter. 2 and 3 came back with NO current at all, 1 2 4 and 6 all had. 1.1 ohm reading 3 and 4 had 0 so I'm guessing glow plugs have given up and are contributing to my starting problems? I also have noticed the car is easier to start when parked facing downhill?? Suspect fuel lines as well?
Any further advice or help is appreciated as I'm now really mind boggled!!
As far as I know I have a battery drain two dead glow plugs and possible air in my fuel lines?
Have I diagnosed correctly as any further diagnoses or further help will be greatly appreciated
I love this car as I only paid £200 for it but I know why now however I'm prepared to spend to fix it up as it's very practical for my family needs
Thank you all!
Thank you all!
