Morning all and merry Christmas to you all
My mercedes E320 CDI UK reg 2001 is having coolant loss.
When you top up the header tank with coolant or water, you look under and NO signs of water dripping at all.
Drive up the road and 5 mils or less and header tank is bone dry, look under and still no signs of water dripping. You top it up and remember it is operating at normal temp, and still no signs of water dripping from under.
Drive another 5 miles or less and loss of header tank again.
No water in Oil, no water from exhaust, and I have checked those I can see hoses, there is a new water pump 5,000 miles ago no leaks around it, and thermostat was changed at same time, I also thought this may be issue so pulled it off and sealed it again on the thermo housing.
Suggestions????
Suggestions????
