ACID
- Sep 29, 2008
- Location
- Birmingham
- C63 Black Series , Mclaren 720s , 992 Turbo S , E63 W213
Right Today We have a few more parts
AMS Turbo Cooler system and Auxiliary Heat Exchanger
Alpha E63 Cooling
Never tried this cooling system so again wanted to see what its gonna be like. Its not the cheapest of items but with extra cooling it should make a good difference in keep the IATs Low.
The Auxiliary Heat exchanger I had in stock as it the same one used in the A45. The E63s comes with 2 Auxiliary heat exchangers but I will only change 1 as they are £700 each to buy, not sure that they will make a lot of difference with the Primary Bigger Heat exchanger and with the extra tank that will be fitted under the wing.
Weistec M157 Downpipes and Exhaust, E63 RWD - Exhaust - 2012-2017 RWD (W212 / M157) - E 63 - E - Products
Weistec True Turbo Down Pipes - We have fitted lots of Downpipes but Weistec have the best quality and plus I had a set in stock. Other Companies like IPE, CKS Fi, Supersprint do Turbo back Down Pipes for a lot for less money.
Idea is to fit the Down + Mid pipes to a custom 3" system straight through with capristo valved back boxes just incase it sounds anti social !!
Weistec Transmission Pan
Weistec 722.9 Transmission Pan - 722.9 MCT Transmission - 2012-2017 RWD (W212 / M157) - E 63 - E - Products
Better cooling, hold more fluid and can add additional Cooler
I Hope to start some Work Monday and will post some more pics Acid
Alpha E63 Cooling
