The developer mode for the newer cars is available with Vediamo.
Also some ECU tinkering via ODX file system
C3 works with versions lower than V5.0 above V5.0 then you have to use a C4
Some bumf off the net:
Vediamo V05.00.05 Software new arrival on EOBD2
Vediamo Development and Engineering Software is for MB SD C4 software new arrival on EOBD2. The current version is V05.00.05. With Vediamo V05.00.05, you no longer need to apply online programming or online to change the SA. You can now use Mercedes Vediamo software any offline for car program, setting code, change the SA Code function. After you place order, we will provide download link of this software for you with activation license. It does not need to change IC and shipment.
Vediamo V05.00.05 features
DTS-MVCI version 08.02.93
GUI for variant coding
Revision of the Service Response presentation and filtration
Support for Vector VNxx VCIs
Monitoring of data blocks while executing diagnostic jobs
Several Bug Fixes
Vediamo V05.00.05 function
Mercedes Vediamo Software is used by the plant engineers to develop diagnosis and engineering software, which is now used by Xentry and DAS, is based on the Mercedes Benz super engineering version developed and delivered to the general customer service dealers’ use.
The use of Mercedes Benz super engineering version has no limitation in diagnosis / modification / programming function are open which cannot be through the VEDOC (the original application code changes with flow) can be free to increase or decrease the SA code, modify the objective, for example: the increase of vehicles equipped with SA500 electric folding mirrors, commonly known as the Xentry and DAS development mode: open data project version in 2010 after the release, increase the number of functional limitations. So we will meet the vehicle version is too new to be into the control unit in use, or are unable to do any special modifications to the control unit.
For example: W204/2122012 instrument to modify the area family configuration, or open other resource advantage function. Diagnosis / Mercedes super engineering version of the code with code / modification / programming database using the Xentry database, so the Mercedes Benz super engineering version is determined with the Xentry version, as long as the database is new and can be used in new models.
Vediamo V05.00.05 vs. V4.00
The V4.00 version that used COMPACT3 SDconnect does not support the ODX file. The latest V5.00.05 SD Connect supports ODX file and SD connects speed is relatively stable.
The latest version Vediamo V05.00.05 (Mercedes Vediamo Software) is used by the plant engineers to develop diagnosis and engineering software, which is now used by Xentry and DAS, is based on the Mercedes Benz super engineering version developed and delivered to the general customer service dealers’ use.
Vediamo - the advanced diagnostic application for engines- is a software system for electronic control unit (ECU) diagnostics which is integrated in the CAESAR/DIOGENES process chain. It allows diagnostics on any ECU over K-line as well as CAN, and encompasses all established protocols from RTMD+, MBISO, KWFB, KW2000 to UDS. Despite its name, Vediamo is no longer limited only to engine ECUs.
Vediamo is based on the Mercedes-Benz DCDI standard communication platform CAESAR and hence supports all communication hardware such as, e.g., Part C, Part A, Part Y, etc. DIOGENES data, used by all diagnostics applications in the company and which can be drawn from the central TAMINO data base, can be used as diagnostics data.
