derekpayne
Hi
Just purchased a C180 (W203 model), and I knew I had to replace the front discs when I bought it, I also have replaced the rear shocks as they were worn.
I have noticed that at around 80mph or any other speed where the engine is at the same RPM range I have a moaning or droaning noise which seems to be coming from the N/S, also the engine appears to be holding back and has a slight misfire.
I have had a good look around, I found one of the exhaust mounting brackets was broken, I welded that up, I thought it may have started resonating at a certain rpm but the noise is still there, and only seems to appear when the I am accelerating at high revs whether it be at 50MPH or 80MPH.
I was going up a long hill yesterday at about 60mph and the noise was there until I throttled off, and the misfire was there as well until I throttled off.
I have checked the plugs and re-gapped them, I just wondered if anyone else had come accross this problem as I cant seem to put my finger on it.
I would be gratefull for any advise or thoughts on this one.
Cheers
Derek
Cheers
Derek
