smithcd
So I was parked up for the night on holiday and I had a message from my local Mercedes service centre that my 2015 E220 S212 was low on coolant. The only coolant available in the town was OAT so I had to fill the reservoir with ~400mL OAT. I know you should not mix IAT with OAT coolant and I believe my merc has SiOAT or Lobrid coolant which is based on OAT… am I ok to run the 400mL OAT which will be now well diluted within the cooling system or do I need a flush and drain ASAP? I couldn’t find any conclusive reputable sources online. I haven’t seen any further drops in coolant volume so far. TIA
