ML 270 CDI - BAS/ESP light on
vbox
Had this light on for 2 weeks now. sometimes stays off for 5 mins before coming on but most of the time on as soon as engine started.
Any thoughts on this please??:dk:
Also noticed today that preglow lamp stayed on for 5 mins before going out. Any ideas why this would have happened. never seen that before!!
Brake light switch or wheel sensor. Try the switch first, it's the cheapest, £12 from MB.
I would go for a brake light switch as well its the cheapest option as per the glowplug light you have one or more faulty glowplugs and requires replacing
thanks. Sounds like a nice cheap solution. Will get one B L switch ordered tomorrow.:)
Hello
Depending upon the year of your ML the brake switch it not under the pedal, its built into the servo, mines a 2003. No brake switch under pedal.... I know I had the the three lights on and looked into this.
I had the codes read at an indy, pointed to a rear wheel speed sensor which was behind the inner arch, the wiring had worn. This was repaired and fixed all for £40
Thanks - mines a 2003 too - will get it checked at indy.
It's a brake pressure sensor, usually the 'common' fault on those. However it could be anything...
