ml heater problem
danny4062
mercedes ml 320
Hi. I am new to the forum and need help please. I have a 2002 ml320 with a heater issue. I cannot get any better than cool air when I set the heater to a high temperature. I have checked that the actuator behind the glove box moves and it seems fine. The heater pipes seem hot and the coolant level is good. I have checked fuses and all is fine. Im not sure where to go from here. Any help is greatly appreciated. Im not bad mechanically but do need detail please. Many thanks.
Don't know about W163, but in W210 common places are jamming duo valves, faulty temp control panel or blocked air con heat exchanger.
I have read in several places about the duo valve and will have to check mine had one. I have removed the glove box and can see the actuator moving with the temp dial so I'm guessing thats ok. How do I check a duo valve or service it please?
Hi guys new to this just wondering how to make a new post i have tried everything and can only seem to reply to new posts any help would be grateful thanks! Sorry if i have interupted on anyones post :D
Sorry to interrupt i am really stuck on how to make a new post all i seem to be able to do is reply on peoples posts :( any help would be appreciated
OP: unplugging connector of the duo valves should cause full heat (if W163 have them). There are plenty of discussion related to W210, try search :)
shane: Do you neec more posts before new thread can be done?
Thank you for the advice I will ceck that it has one. My understanding is that it is next to the brake master cylinder.
If your question is about electronics then go here… Electronics - MBClub UK - Bringing together Mercedes Enthusiasts …near the top of the page you will see a button like this…
Click it and type your question.
Dec
This is what u have which doesn't look like the valves ive seen online. Can anyone please help as to whether this should be checked and if so how do I go about it. Many thanks in advance.
Thank you but I dont seem to have the same duo valve but rather something different as in my picture
Yes looking at the pictures you attached it is definitely that. Would a faulty one stop the heater working. The engine temp is very consistent at 80 degrees
I have just warmed the engine up to operating temp. I can feel a slight buzz from the pump when I put my hand on it and the hose going into the bottom is quite hot andthe ones coming out of the top are just warm. When I turned the engine off the pump buzzing stopped as well. Am I perhaps mistaking the pump buzz as vibration from the engine? Is there anyway to check the pump ?
The hose going into the bottom of the pump and the hose coming out of the pump should both be equally hot if water is circulating through the pump.
This is an American manual but see page 110 residual heat switch 7 here… http://www.mbusa.com/vcm/MB/DigitalAssets/pdfmb/ownersmanual/2002_ml.pdf
And
Page 117 residual engine heat utilization, get engine up to 80c and see if the pump will run with the key in ignition 1 position as described in page 117.
Dec
thank you, I have just tried that and the pump doesnt buzz at all, the engine temp was just over 80 degrees, i turned the key to both position 1 and 2, and although the pipes above and below the pump were hot, i could not feel the pump buzzing....
In the left side of the picture below is my recirculating pump, if I touch the end nearest the bottom, where the wires are, I can feel the vibrations of the motor, at the other end I can feel the pulse of the coolant as it goes through the pump so if you don’t get any vibrations then the pump is dead or not getting any power.
Unplug the pump and check for 12v.
Check fuses also.
Dec
attachment.php
thank you, on mine it is the same pump but vertical, I will check it tomorrow with my vltmeter, but im sure theres no vibration as you describe, I have found another on the internet should i need a replacement, i did check the fuses but on mine it must have several functions as there isnt one on the list purely for the pump, does yours have a separate fuse?
