The only way of doing properly integrated is to retrofit the factory system. It is possible but it is stacks of work as it means both front seats out, etc etc
Thanks. Was thinking more of aftermarket options, that gave functionality through Command i.e. Uses existing controls/screen etc, or is this the same hassle regardless of what kit is used?
Sorry, should have been more specific. There is no aftermarket DAB kit that uses existing controls for NTG4.5 (which is what you have in your W166 ML)
The closest you can get is something that has a separate control mechanism and uses FM to transmit it's sound to the stereo so you see the station data as RDS text. Alternatives are a complete separate display and uses AUX in (which sounds better).
