Hi all
I have a 2006 ml320 w164. a few weeks ago I started getting the Airmatic warning Visit Workshop warning light. It seems to come on after about 20 minutes of driving and disappears when the car starts up again. Comfort, Sport and Auto all seem to function fine and the car has not dropped on any sides.
Am currently looking for a good independent Merc dealer in Manchester...but before i take it to them I wanted to know if any one had experienced anything similar and what the resolution was. A bit wary about getting done over by a garage.
The errors below are what I've got from the Carly software on my phone.
Any thoughts, comments etc will be much appreciated!
AIRmatic (MB: 2515451832)
Fault: Recovery time during filling of central reservoir is too long. Code: 005503
ESP - Electronic stability program (MB: 2515450832)
Event: CAN signal 'Ratio' from control unit N15/3 (ETC [EGS] control unit) is implausible. / Fault: DTR : CAN signal 'Ratio' from control unit Transmission control module is implausible. / Fault: DTR : CAN communication with transmission control unit is faulty. DTR : The CAN message from control module N80 (Steering column module) is invalid or implausible. ( Cruise control lever )
Code: 007223
Event: CAN signal 'Target/actual gear' from control unit N15/3 (ETC [EGS] control unit) is implausible. / Fault: DTR : CAN signal 'Target/actual gear' from control unit Transmission control module is implausible. / Fault: DTR : CAN communication with transmission control unit is faulty. DTR : The CAN message from control module N80 (Steering column module) is invalid or implausible.
Code: 007222
Event: One or more signals sent from control unit N51 (AIRmatic with ADS control module) via the CAN bus is implausible.
Code: 005539
Event: The supply voltage of the control unit is too low (undervoltage). / Fault: SIC - Long term compensation disabled. (FP: 20 FT: 01)
Code: 006001
HAQ - Interwheel differential lock at rear axle (-)
ECU not present/no response from ECU
Code: 007223
Code: 007222
Code: 005539
Code: 006001
