spedge
Hi All
I have a 2000 ML320 W163 110,000 miles, that is showing a only P0302 No.2 Cylinder Misfire.
The misfires only occur under very heavy acceleration at over 4500-5000rpm.
keeping it under this rpm it is fine, turn ignition off and on and fault clears.
I have replaced the Plugs x 2, Leads x 2 & Coil pack (tried 3 different ones) and also tried a new MAF.
The car originally had several misfires across multiple cyclinders but it was overdue a good service (all plugs now changed) and only this code comes up.
What are the next steps to check, could it be an injector?
Your help and support is greatfully received and help me out many times before.
Thanks in advance
Simon
Thanks in advance
Simon
