I cannot see any exact similarity with other forumites juddering problems, so perhaps someone can advise on the following.
I have an '02 320CDI Estate with self levelling suspension. In the last 8k miles, I have had the following replacements by my specialist independent garage who maintain the vehicle: both front shock absorbers, new brake pads all round, new front discs (twice), two new calipers,two front tyres 5k miles ago..
I had some juddering 4k miles ago (December) and the discs were replaced as they had inexplicably warped, the pads were refaced and all was well until last month. The car then developed sever juddering at speeds between 65-70mph AND on braking firmly at anything above urban speeds.
I had the tracking checked,all four wheels rebalanced and the two rear tyres replaced as one was distorted and couldn't be balanced. Replacing the two rear tyres cured the speed vibration but that in turn revealed that the braking judder, which can be felt through the steering wheel and driver's seat was still there. Although not quite so bad it is still sufficiently severe to be alarming when the car is hauled down from fast speeds and noticeable at town speeds too.
The car has been back to the garage for a quick inspection and no fault with the suspension or steering gear has been found so far but the plan now is to take it back for a few days so that, in the first instance, new discs can be installed on the rear end- if this doesn't do the trick then they will be replaced with the old discs on a ' no cost' basis, very fair treatment I reckon.
However, since the juddering is obvious through the steering wheel I'm convinced, but without any evidence that it is a front end problem.
There is just one thing that I am uneasy about and will address, and that is that when my combined steering pump/self levelling oil reservoir fell to minimum about 9k miles ago, M-B sold me the wrong fluid even though they checked the VIN details on their computer. Seemingly many such cars have independent oil reservoirs, not combined units such as mine and it wasn't until I had poured in half the litre bottle of top-up oil that I noticed that the part number on the filler cap on the car and the part number on the bottle were different. On querying this with M-B they told me that a mistake had been made (my words not theirs!) and that the fluid I had introduced was never intended for steering pumps but that it wasn't a safety issue and it was my choice if I wanted to flush out and replace- I decided to wait until August this year when an 'A' service is due.
When I reported this to my garage they showed suprise as they too were unfamiliar with the combined reservoir arrangement(seemingly the more common steering pump reservoir is concealed under the engine cover which has not been needed to be removed,the car has done only 104k miles) and they tell me that they habitually use a generic ZHM type fluid such as Citroens use.
The reservoir level has remained unchanged since the my top up, so any mixing could be minimal but a similar quantity (perhaps 1L) was introduced at service last summer. Could this be a contributory factor in anyway?
