Hairy1305
- Aug 16, 2020
- Location
- Wedmore, Somerset
- C123 230CE, Ford Ranger Wildtrak, VW UP, W108 coming.
Hahaha, yeah, know the smell well!
OK, have found water, in the rear nearside footwell. I've dried it out, removed the carpet and checked the scuttle panels, which channel water properly.
From the chap at W123 world:
"Wet rear carpets indicate either a leaking Sunroof ( Which you have said it's not), check if water is running along the central locking pipes/ covers into the rear from the front foot-wells. Often there are leaks behind the bonnet springs ( if the drain cavity is blocked) water runs into the front wells and down into the rear. Or possibly a major rear screen leak. Only way to check that is to remove the back seats, which I'll do tomorrow."
Next time it rains, I will sit in the back of the car and see where the water comes from, but slowly thinking rear screen leak.
Again, thanks.
Again, thanks.
